Hello Guest it is November 13, 2026, 09:17:19 PM
Author Topic: Sreen display problems  (Read 11964 times)
« on: March 01, 2008, 06:56:52 AM »
I have down loaded mach3 demo version onto a XP pro desk top PC. All loaded ok but I am getting the top blue bar in several places on the screen mostly on turn manual or auto but also shows up in the reset button area of mill or plasma screen. I have tried to uninstall and reinstall with no results.
Re: Sreen display problems
« Reply #1 on: March 01, 2008, 09:32:23 AM »
Looks like you may have a corrupted screenset, try going to the view menu then Load Screens, then choose the 1024.lset and see if it helps. If it doesnt then have a look under the config menu then general config and change the setting you have for Auto Enlarge.
 If none of these help it may be your graphics card, try reducing the hardware  acelleration for the card.
« Reply #2 on: March 01, 2008, 10:16:25 PM »
Thanks for the reply Hood. I tried your suggestions and had no change. I took my PC to a repair facility and ended up replacing the video card with a higher end video card and all is well now.
