Hello Guest it is September 17, 2026, 11:13:59 AM
Author Topic: re tab out jog control  (Read 10721 times)
« on: February 29, 2008, 11:50:21 AM »
is there a way to change the direction of the arrows in the jog control. so the arrows acutally go the direction that they should so if i push left it goes left or right .any help would be greatly appreciated this just drives me nutts the way it works.
Offline Greolt
  •  956 956
Re: re tab out jog control
« Reply #1 on: March 01, 2008, 07:01:17 AM »
The arrows are correct if you are standing in front of the table and origin is lower left. This is conventional.
If the axis is moving in the wrong direction that can be changed in,
Config / Homing and Limits / check "Reversed"
Greg
Offline PaulWC
  •  125 125
« Reply #2 on: April 06, 2008, 11:31:16 PM »
It makes it easier to use the arrows if you concentrate on spindle movement, rather than table movement... as though the table were stationary. It took me awhile to figure that out, but I now move the table in the correct direction without thinking.
Paul, Central OR
MiniMechanicals.com
« Reply #3 on: April 06, 2008, 11:59:57 PM »
Paul is right. I agree, it is confusing a little but there is a reason. As Greg said, it is conventional. I could have re-mapped the keys, but thought it best to bite the bullet and get my head around the +/- thing. If not, would be more confusing to look at G-code files and and be able to comprehend what was going on.
