Hello Guest it is November 01, 2026, 10:02:15 AM
Author Topic: Newbee here with a question about tool offsets.  (Read 13594 times)
« on: February 25, 2008, 08:22:11 PM »
Trying to develop the g-code to do the gear teeth shown in the details attached.
Problem is when I set the tool to a 1/16 (.0625 dia.) end mill and the connection tolerance to .001 (or any other value), LazyCam refuses to cut the area between the teeth; it wants to skim over the individual tooth tops.  In the cad file I’ve measured the distance between the teeth to be .114; that should be plenty of room for the cutter to offset between two teeth.
Interesting thing is if I ask it to offset it on the inside instead of the outside it has no problem creating the chain.
What am I missing here?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Newbee here with a question about tool offsets.
« Reply #1 on: February 25, 2008, 08:38:16 PM »
Hi, Thetgarey
Post your dxf use the REPLY button then Additional Options and attach.
Thanks, Chip
« Reply #2 on: February 26, 2008, 04:57:06 AM »
Good Morning Chip,
Attached is the DXF file for the gear, hope this helps in clearing up whatever it is I'm not getting.
Thanks for the help.
Tadd
Offline docltf
  •  354 354
« Reply #3 on: February 26, 2008, 12:01:52 PM »
thetgarey
       put this move on it,scale your drawing up 4x1 use a .250 tool then scale back to size.
bill
Offline Chip
  •  2,055 2,055
« Reply #4 on: February 26, 2008, 12:05:50 PM »
Hi, Tadd
I didn't pay attention to your second pic, LazyCam sometimes gets the in-outs backwards, Using LC 3.00.2 hear and in-outs are correct.
As long as the path is proper it should post it that way.
Thanks, Chip
« Last Edit: February 26, 2008, 12:08:39 PM by Chip »
« Reply #5 on: February 26, 2008, 06:42:40 PM »
Hi Chip,
That worked, really apreciate the help, I'll remember that trick in the future.
Tadd
