Hello Guest it is November 13, 2026, 02:46:30 PM
Author Topic: Jog HotKey gets stucked!  (Read 30527 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Jog HotKey gets stucked!
« Reply #10 on: February 25, 2008, 08:05:35 PM »
Hi, Gilbert
Maybe you can use a brains similar to this one, Haven't looked at your screen set at this time, But I will
http://www.machsupport.com/forum/index.php/topic,4897.0.html
Just a Thought, Chip
« Reply #11 on: February 25, 2008, 10:56:26 PM »
Hi Bodini
So the problem appeared at random times in your system ?
Gilbert.
« Reply #12 on: February 25, 2008, 10:59:39 PM »
Hi Chip
Sure I will take a shot at it.
Thanks!
Gilbert.
Offline Bodini
  •  216 216
« Reply #13 on: February 25, 2008, 11:26:09 PM »
Yeah.  I'd be jogging along and let go, and the jogging axis would just keep going.    It happened to other people at my machine too.  Like I said, I never figured it out and it hasnt happened in probably 6 months.  One thing I always suspected is that by pushing the shift key, then the arrow key to jog, and then letting go of the shift key (and then releasing the arrow key) might have done it.
-Nick
Offline Chip
  •  2,055 2,055
« Reply #14 on: February 25, 2008, 11:38:17 PM »
Hi, Gilbert
List the button text with button description, I'll work on it a bit hear.
Thanks, Chip
« Reply #15 on: February 27, 2008, 01:45:07 PM »
Hi Chip
Sorry for the delay!
I hope this is the info you need:
The buttons I'm  talking about are located in the right upper corner of
page1 of the scrren i attached to a earlier post on this thread.
The Captions are X-FB++,X-FB--,Y-FB++,Y-FB--.
They have the corresponding hot keys from the numeric keypad assigned.
And they are supposed to jog axis X+A simultaneously and Y+B in the same fashion.
Thanks again!
« Reply #16 on: February 27, 2008, 02:28:25 PM »
Sorry I missed this earlier where you posted your screen set, just looked at it now and it is OEM codes, I had thought maybe it was VB buttons. I however cant get it to Jog as it says there is a VB Failure so looks like you need additional script for this which I dont have.
 Not sure how USB pendants work but if you can set the button up as an OEM trigger then you could asign the Jog buttons OEM to that trigger.
« Reply #17 on: December 27, 2016, 08:32:41 AM »
I am sure this is a elemetry question but what do you mean by "FB"?
I am attempting to set the jog codes per the above "ScreenHunter_03_Feb... but can not determine how to get the same codes.
(The Captions are X-FB++,X-FB--,Y-FB++,Y-FB--)
Thank you.
BretC
