Hello Guest it is October 22, 2026, 06:44:25 PM
Author Topic: how do I block delete  (Read 15021 times)
« on: May 03, 2006, 01:36:16 PM »
Using Mach II my posts place a double forward slash in front of remarks. Mach II does not read blocks, lines, prefaced with double forward slashes. On the other hand, Mach III errors on double forward slashes and stops processing the program. It was suggested I need to activate "enable block delete". Seems simple enough but through all the searching I've done I can't find a switch to enable block delete. How about it, does it exist and where do I find it.
jim
