Hello Guest it is November 13, 2026, 10:01:09 AM
Author Topic: Perske Spindle  (Read 17884 times)
Perske Spindle
« on: May 02, 2006, 08:22:18 PM »
My company bought a Gerber Sprinter 48.  It is a very nice machine.  But the software is abit lacking.  Im looking to switch it over to mach software.  Well i need to know how to control the spindle.  I know how to do the steppers and the homes and limits and stuff.  But im abit confused about the spindle.
Its a 5.5hp Perske Spindle if that helps.  It was microproccessor controlled spindle on the side of it.  It has a small LCD which displays its rpm.  It also has a switch on it that has ABCDE on it.  I figured this was a varable speed type switch.  It runs off 220v.
If anyone can help me that is great.
Thanks Eric,
Re: Perske Spindle
« Reply #1 on: May 02, 2006, 09:53:30 PM »
You could put on a VFD and have mach3 run the VFD...
www.newfangledsolutions.com
www.machsupport.com
Offline fdos
  •  326 326
Re: Perske Spindle
« Reply #2 on: May 05, 2006, 06:35:44 PM »
Sure it's not a Penske?   They also make high speed spindles.  Or at least I thought they did <g>
But most of these high speed spindles require an inverter (VFD drive) as Brian suggests.   Most run to 300Hz or so.
Wayne...
« Last Edit: May 05, 2006, 06:43:03 PM by fdos »
