Hello Guest it is October 21, 2026, 12:24:09 PM
Author Topic: A million dollars to the person that can help me.  (Read 28613 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: A million dollars to the person that can help me.
« Reply #10 on: February 25, 2008, 06:05:14 PM »
Hi, Barry
Give us a list of the boards/cards your using.
Thanks, Chip
Re: A million dollars and board specs
« Reply #11 on: February 25, 2008, 06:13:40 PM »
Hi
The breakout board is bob campbells version 1.8 ...I believe. And also a sound logic
encoder interface board sold by rogers machine. Both boards require a parallel port
cable. The Geckos are G320 and they run on a 53 volt supply. The encoders are E2
250 line US Digital devices.
Offline Chip
  •  2,055 2,055
« Reply #12 on: February 25, 2008, 07:10:20 PM »
Hi, Barry
May have a bad xml file.
Look in C:\Mach3\xmlbackups folder, It has backup xml's, Sort it by Date, Make a copy of the one that is just before the date you started having trouble.
Past it in C:\Mach3\ folder, Then re name it th Mach3Test.xml and load it, Give it a try.
With the boards your using there are a lot of special settings, It's probably the encoder interface board's settings your missing.
Thanks, Chip
« Last Edit: February 25, 2008, 07:12:16 PM by Chip »
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #13 on: February 26, 2008, 02:06:23 AM »
Are you using 2 parallel ports, if so, is the second one configured for just inputs?
Graham.
« Reply #14 on: February 26, 2008, 05:57:14 AM »
One parallel  port controls the breakout board and the other controls the encoder interface card
Barry
« Reply #15 on: February 26, 2008, 04:14:45 PM »
I tried a older xml . I still have the same runaway condition.
Hi, Barry
Thanks, Chip
