Hello Guest it is October 28, 2026, 08:17:11 AM
Author Topic: Terminate a brain with "run macro M650.m1s" ???????  (Read 128025 times)
Re: Terminate a brain with "run macro M650.m1s" ???????
« Reply #20 on: March 19, 2013, 07:46:23 AM »
Thanks Brett and Scott,
i understand what you mean Brett, so i'm trying the below. not sure
about brains...still learning as i never saw anything like brain.below changes
the leds but i have to change the 0,1 positions in the script.
Scott,
i couldn't get yours to wotk(you were missing a parenthesis
if i changed 1,0 position, it did change the led. but didn't change
when i would jog an axis. one more thing is that i didn't have a userDRO(2000,2001 or 2002)
not sure if i was suppose to make em or they're a system defaults.
Thanks again
X = GetUserLED(1120)
Y = GetUserLED(1121)
Z = GetUserLED(1122)
If IsMoving() Then
   GetOEMDRO(0)
   SetUserLED(X,1)
Else
   GetOEMDRO(0)
   SetUserLED(X,0)
End If
If IsMoving() Then
   GetOEMDRO(1)
   SetUserLED(Y,1)
Else
   GetOEMDRO(1)
   SetUserLED(Y,0)
End If
If IsMoving() Then
   GetOEMDrO(2)
   SetUserLED(Z,1)
Else
   GetOEMDRO(2)
   SetUserLED(Z,0)
End If
Kenneth
« Reply #21 on: March 19, 2013, 08:19:53 AM »
stepping thru this, the program skips over the If
and goes straight to the Else. is this right ?
if i change SetUserLED(X,1) to SetUserLED(X,0)
the led changes
Kenneth
« Reply #22 on: March 19, 2013, 08:39:31 AM »
If an led is one, it is on.  The leds are two state images.  Half the pictur is for on, the other half is off.  If the image doesnt have the right picture on the proper side, it will reflect the opposite of what it actually is.
« Reply #23 on: March 19, 2013, 08:41:51 AM »
i have other leds that work as should. where do i find these pictur ?
Kenneth
« Reply #24 on: March 19, 2013, 09:03:08 AM »
Open your screen in Mach screen and look at the properties for the led.  That will tell you where the picture resides.
« Reply #25 on: March 19, 2013, 09:07:58 AM »
the image path is - None -
all my user leds have none but they work.
and all my picture are in Mach3\Bitmaps
and sub folder MillBitmaps
and i have Red/Green LED = Yes
« Last Edit: March 19, 2013, 09:14:13 AM by Kenneth »
Kenneth
« Reply #26 on: March 19, 2013, 01:41:47 PM »
this doesn't change no matter 0 , 1
If IsMoving() Then
   GetOEMDRO(0)
    SetUserLED (X,1)
   GetOEMDRO(1)
    SetUserLED (Y,1)
   GetOEMDrO(2)
    SetUserLED (Z,1)
Else
   GetOEMDRO(0)
    SetUserLED (X,0)
   GetOEMDRO(1)
    SetUserLED (Y,0)
   GetOEMDRO(2)
    SetUserLED (Z,0)
End If
Kenneth
« Reply #27 on: March 20, 2013, 05:04:47 AM »
tried below again and added a UserDRO(2000) and when i changed
SetUserDRO(2000,CurrZPos) to tried below again and when i changed
SetUserDRO(2000,CurrZPos)  to SetUserDRO(2000,100) it changes
the dro(2000) to whatever i change the number to. so i was wondering
if "Curr?Pos" works? as the dro never changes with Curr?Pos. not sure
about Old?Pos either :)
X_MovingLED = 1120
Y_MovingLED = 1121
Z_MovingLED = 1122
CurrXPos = GetOEMDRO(800)
OldXPos = GetUserDRO(2000)
CurrYPos = GetOEMDRO(801)
OldYPos = GetUserDRO(2001)
CurrZPos = GetOEMDRO(802)
OldZPos = GetUserDRO(2002)
if CurrXPos <> OldXPos then
   SetUserLED(X_MovingLED,1)
   SetUserDRO(2000,CurrXPos)
else
   SetUserLED(X_MovingLED,0)
end if
if CurrYPos <> OldYPos then
   SetUserLED(Y_MovingLED,1)
   SetUserDRO(2000,CurrYPos)
else
   SetUserLED(Y_MovingLED,0)
end if
if CurrZPos <> OldZPos then
   SetUserLED(Z_MovingLED,1)
else
   SetUserLED(Z_MovingLED,0)
end if
« Last Edit: March 20, 2013, 05:18:26 AM by Kenneth »
Kenneth
« Reply #28 on: March 20, 2013, 06:23:36 AM »
Never mind :)
i see what i misunderstood about Curr?Pos and Old?Pos
Kenneth
« Reply #29 on: March 20, 2013, 07:02:43 AM »
clicking run continuely in the VB editor makes the UserDRO(2002) change.
and about every third to fifth click makes the UserLED change(Red/Green)
the UserDROs 2000 and 2001 never change that i can see
X_MovingLED = 1120
Y_MovingLED = 1121
Z_MovingLED = 1122
CurrXPos = GetOEMDRO(0)
CurrYPos = GetOEMDRO(1)
CurrZPos = GetOEMDRO(2)
If CurrXPos <> OldXPos Then
Else
End If
If CurrYPos <> OldYPos Then
   SetUserDRO(2001,CurrYPo0)
Else
   SetUserDRO(2001,CurrYPos)
End If
If CurrZPos <> OldZPos Then
   SetUserDRO(2002,CurrZPos)
Else
End If
« Last Edit: March 20, 2013, 07:04:24 AM by Kenneth »
Kenneth
