Hello Guest it is October 28, 2026, 08:17:28 AM
Author Topic: Terminate a brain with "run macro M650.m1s" ???????  (Read 128026 times)
Re: Terminate a brain with "run macro M650.m1s" ???????
« Reply #50 on: March 26, 2013, 11:13:44 AM »
the file i'm using is in that folder and i don't
have a file named macropump.m1s in there.
and i did try this before, it just changed the leds once
bunch of m##.m1s
thanks
p.s. if i don't have the DROs in the set file, will it work ?
« Last Edit: March 26, 2013, 11:22:51 AM by Kenneth »
Kenneth
« Reply #51 on: March 26, 2013, 11:22:42 AM »
Should be there, you must have lost it.  :D
Put you another one there, open the editor, paste in the stuff, then name Macropump.m1s.
No prob.
Russ
« Reply #52 on: March 26, 2013, 11:27:57 AM »
Better yet, just plop this in your profile macros folder
Just remove the KENNETH_
« Reply #53 on: March 26, 2013, 11:31:06 AM »
yep .. you dont need to see 'em, the macro is comparing them so it can show you the led's ... you dont need to see 'em at all.
« Reply #54 on: March 26, 2013, 11:40:27 AM »
i copied the file to c:\mach3\macro\userprofile
looked at my set file to see if the LEDS and DROs
were set the same(they are). i'm missing somethinbg else
as this doesn't do anything but change the LED once and
doesn't change the userdro to the same as oemdro.
will delete the dros after i get this straight
Kenneth
« Reply #55 on: March 26, 2013, 11:44:16 AM »
Do you have "Run Macropump" checked in Gen. Config ?
« Reply #56 on: March 26, 2013, 11:46:01 AM »
then shut down Mach and restart ... just for shts n' giggles.
« Reply #57 on: March 26, 2013, 11:53:47 AM »
did that(twice...while giggling)
when i open mach3, Y leds is lit. if i move it
with arror keys. it goes off(0) but if i move Z,
y dro changes. i check the set file and they are different.
yes Pump is clicked in general
oemdro = x 800
y = 801
z = 802
userdr = 2001 - 2002  -  2003
(changed em to stop using 2000)
p.s. i renamed the file from KENNETH_Macropump.m1s
to Macropump.m1s.
« Last Edit: March 26, 2013, 12:00:36 PM by Kenneth »
Kenneth
« Reply #58 on: March 26, 2013, 12:05:50 PM »
;D
You did change every instance of the new dro's in the macro ?
You have tried so many things, you might have internal conflicts. Get rid of anything you're not using (been there)
Also, mine blinked a little strange at first (i think), loaded and ran a small gcode file and it's been perfect ever since. (don't know why that would matter though).
« Reply #59 on: March 26, 2013, 12:16:59 PM »
shut down mach3 and machscreen. opened macropump
and checked everything. i did have the dros off by one number.
(don't know why that matters) opened mach3 and poof....
working. they blink if i jog a few seconds but think it's just because
of the loop. THANKS !!!!!!!!!!!!!!!!!!!!!
Kenneth
