Hello Guest it is October 30, 2026, 12:34:11 PM
Author Topic: Missing Steps  (Read 57710 times)
Re: Missing Steps
« Reply #20 on: May 18, 2006, 02:30:29 AM »
I ran twice through a pattern that takes about 20 minutes to cut.  No problems this time.  It used to start loosing steps about 10 minutes in and get progressively worse.  But after the changes, its all good.  Cool!  Now I can use Mach3  Thanks!!!
Re: Missing Steps
« Reply #21 on: May 18, 2006, 06:12:15 AM »
Very Good! No you can't do anything to hurt a stepper  ;D Other than taking a hammer to it I think you are safe
Happy cutting
www.newfangledsolutions.com
www.machsupport.com
Re: Missing Steps
« Reply #22 on: June 22, 2006, 08:48:16 AM »
Art, Brian, Someone!!!
I have read every post about missing steps in the "Y" axis and applied all of the fixes i could understand.  When configuring motors the "Y" AXIS runs fine (no skips).  I have changed motors from one drive to other to see if it was the motor - no difference.  Changed out cables - no help.
I have shut velocity and acceleration down to minimums or set to maximums and still get skips.  Changing to Sherline mode did not help.
I even pulled the lead screw our of the "Y" axis to determine if it was screwed up or blocked.  Looks okay.  Like I said - "Y" works fine when in the motor tuning mode.
I have determined in MIDI when I type in same distances for "X" and "Y" ex: G0x4 y4 - Y4 "Y" does not skip steps.  If I type in different  distances - ex: G0x4 y2 - "y" skips steps.  It isn't compensating for the differences.  The machine coordinates are wrong for "y" after the exercise.
Any suggestions will be appreciated.
Bob
Re: Missing Steps
« Reply #23 on: June 22, 2006, 12:52:23 PM »
Could you pleae run a driver test and tell me what you see?
www.machsupport.com
Re: Missing Steps
« Reply #24 on: June 22, 2006, 05:15:34 PM »
Brian, ran a driver test and here is what I recorded (Mach3 not running)
Interrupt Used 00
Pulse per sec. 23517
APIC Present - Green Box
CPU Speed - 3067
APIC Timing - 5642
Shortest time 36,157 (I think)
Longest time 48, 700
Line variations basically flat with occ. 1/8" spike
With Mach3 Running:
Interrupt Used 00
Pulse per sec. 25812
CPU Speed - 3067
APIC Timing - 5642
Shortest time 32,950
Longest time 32,950
No activity Line
No other programs are running when I am running Mach3.
Thanks for looking
Bob ???
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Missing Steps
« Reply #25 on: June 22, 2006, 06:23:53 PM »
I was wondering if buying the:
"Campbell Designs" "Breakout Board Plus
for Mach2 and Mach3"
would solve the voltage problem caused by new computers and what other advantages there are to having it or if it helps with allot of problems people are having?
Re: Missing Steps
« Reply #26 on: June 22, 2006, 06:29:09 PM »
Bob's board will fix the problem of a low voltage printerport :)
I think you should look into the optimization and see if there is something in there that is making the spikes..
Thank you
Brian
www.machsupport.com
