Hello
Guest
it is
October 03, 2026, 11:36:09 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Brains Development
Newby – brains to turn the coolant on/off ?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Newby – brains to turn the coolant on/off ? (Read 13217 times)
chucky
25
on:
February 20, 2008, 01:40:41 PM »
I am trying to make a brain to turn the coolant on only when the G-code is running and the Z-axis gets with-in .125 from the part and lower.
Any hints?
My coolant or mist is on output 4
thx chuck
Logged
poppabear
2,235
Briceville, TN, USA
Re: Newby – brains to turn the coolant on/off ?
Reply #1 on:
February 20, 2008, 10:31:26 PM »
Ok here is a brain,
It looks at the Run LED, and Z position dro, (assumes -Z is going down into your work, and 0 is the work top surface).
it then turns on output4 when z is less than .125
scott
Logged
chucky
25
Reply #2 on:
February 21, 2008, 07:54:52 AM »
Thanks a million poppabear it works like a champ and helped me figure out how this works.
Logged
Print
Pages:
1
Go Up
« previous
next »
