Hello Guest it is November 22, 2026, 08:35:34 AM
Author Topic: Functionality idea  (Read 35408 times)
Functionality idea
« on: February 18, 2008, 08:15:49 PM »
Hi Guys
I've been watching this and other threads with great interest (now I really need to get my machine finished).
I had a bit of an idea last night which you may or may not have thought of as a functionality / feature for you plug in.
If you can set a pixel position of the laser line once you set tool height and save this as a tool offset you have a non contact material height sensor.
If you add edge detection you can find the material X,Y (0,0)
For the edge detection I would think you would want 2 laser lines at 90 degrees to each other or possibly a single one at 45 degrees to the workpiece. In the first instance (2 lasers) you would look for a drop in height of each, in the later (single beam), the line will get shorter and shorter until it drops off.
What ya think?
Mark
« Last Edit: February 18, 2008, 08:55:09 PM by mhasting2004 »
