Hello Guest it is November 10, 2026, 01:54:08 AM
Author Topic: Need to interupt while loop  (Read 9145 times)
Offline Whacko
  •  239 239
  • Happy Days
« on: February 15, 2008, 03:49:38 PM »
I am using a system key in Mach3 to interupt a while loop by monitoring a led state. The OEM buttons and OEMled's has a low priority in a macro while loop it seems. I have worked around it, but can't locate info on buttons that has a higher priority and is not assigned to Mach3 system. Is there available buttons for such an interupt?
I am monitoring a button/led while in a timer loop as to terminate the loop via external interupt premature to the timeout.
Whacko
Nothing's impossible
Re: Need to interupt while loop
« Reply #1 on: February 15, 2008, 09:04:10 PM »
Redo your While conditon Put and "OR" in your while and the other part is your escape conditon
While (what I am waitin on here) OR (IsActive(INPUT2)) (INPUT2 your escape clause, or button, or led here)
Offline Whacko
  •  239 239
  • Happy Days
« Reply #2 on: February 16, 2008, 02:18:48 PM »
Hi Scott, thanks for the input, but that won't work. I'm in a timer loop. Whilst in the timer loop, OEM buttons don't trigger an interupt in the kernell. I think I got the answer though. I didn't think of it but it has something to do with the button group.
Whacko
