Hello Guest it is October 25, 2026, 02:59:08 AM
Author Topic: problems with mach3-hardware  (Read 10308 times)
« on: February 12, 2008, 01:37:06 AM »
Dear Sir,
I have designed a PCI interface card in two ports, 32-bit input and 32-bit output ports with given IO base address.
I am working with MACH 3 by assigning them (ports) as address base 2 for prime tests.
I face to some followed questions:
1-Is it possible to use all 32 bits input and output via MACh3 or they are available just in 8 bits as output and 5 bits as input, like printer port?
2-While running software (MACH3), it seems a little jitter in sending pulses to an AC servo motor from FUJI brand. Could you explain about it, please?
3- Can Mach 3 close the control position loop or the encoder data are just to show on screen? If the AC servo driver could not retrieve lost pulses, How MACH3 can handle it?
4-If I apply G100 or other similar hardware modules, what changes maybe occurred to answers (3 above questions)?
Your kindly reply can help me to solve my problems.
Thanks in advance.
Best Regards.
F.Khalaj
f_khalaj@yahoo.com
