Hello Guest it is November 13, 2026, 09:45:56 AM
Author Topic: Home switch position  (Read 35072 times)
Offline DAlgie
  •  314 314
    • Algie Composite Aircraft
« on: April 29, 2006, 08:35:31 PM »
I looked through other posts, but, is the home position, where you reference your machine from, always at the end of the axis? What I'm asking is, can a home position be located in the middle of a travel, or somewhere along it? My lathe has a reasonably long bed, and with a low pitch ballscrew it is a ways to go to get a reference point, if the home position was able to be set closer to the work area it might be a nice feature.
                                DaveA.
ynneb
Re: Home switch position
« Reply #1 on: April 30, 2006, 04:08:06 AM »
Yes you can set your home switch at any point in the machine travel.
While I dont know the exact procedeure for doing this, I think it is done using a macro.
But it can be done, that much I can definately tell you.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: April 30, 2006, 04:11:12 AM »
Hi Dave,
You can have the home position where you want, one of my mills at work has the home position on the X and Y table centre line.
The home position is only really a starting point for the control, so it knows where to start counting from.
Graham.
Offline DAlgie
  •  314 314
« Reply #3 on: April 30, 2006, 09:43:11 AM »
Very cool, thanks. I went back to it late last night and understand how it works now. I would imagine that you need to make sure the saddle is on the same side before homing so the home direction setting sends it that way, if you were on the opposite side the control would run it away from the trip point to never never land, or the end of it's travel, whichever came first....
Offline DAlgie
  •  314 314
« Reply #4 on: May 01, 2006, 12:33:53 AM »
Well, got the home switches installed, and the trip points. This is a lathe, set the X axis switch at the max X position, and the Z axis switch at about the middle of it's travel. Two questions now, how do I send the machine to find the home switches? I made sure the motors were active, they jogged fine, then pushed the home buttons, I tried the x home, then the z home, then the all home, nothing happened, no movement. Second question, when I jogged to find the home switch, it shut off the motor as it should, but then I couldn't reverse off the switch, the Estop remained on, and I couldn't go anywhere. I had to go into the diagnostic screen and hit limit override to get it off the switch. I seem to remember Art saying something in one of the videos about this, but I can't find it for the life of me.
« Reply #5 on: May 01, 2006, 05:43:33 AM »
It should just start moving.. Do you have the home pins turned on under the ports and pins?
www.newfangledsolutions.com
www.machsupport.com
Offline DAlgie
  •  314 314
« Reply #6 on: May 03, 2006, 12:43:26 AM »
Yes, have the home pins turned on, tried all directions and settings I can find that seem to be applicable to homing. The home switches work, they stop the motors, so this has me confused a bit. I have the correct pins set for this also. Maybe something strange with the lathe side of Mach, I don't know.
« Reply #7 on: May 03, 2006, 05:13:45 AM »
Can you press the switch and see the state change on the Diagnostics page?
Also what do you have for inputs that are active?
www.machsupport.com
Offline DAlgie
  •  314 314
« Reply #8 on: May 03, 2006, 11:19:17 AM »
Yes, pressing either home switch lights up the home light on the diagnostic page ok. No abnormal lights seem to be lit, I am having spindle feedback problems or something like that though, the spindle speed goes haywire a lot, sometimes it settles down and reads the correct speed when running, and it's light on the diagnostic page flicks on and off randomly, but I figured that this was inductive feedback. Didn't think that would be doing anything to the home switch settings though. Thing that has me confused is that the home switches work as limits ok, so I imagined that they are doing what they are supposed to.
« Reply #9 on: May 03, 2006, 01:42:29 PM »
Try setting your debouce to 2000 (20us)
www.machsupport.com
