Hello Guest it is October 21, 2026, 06:10:49 AM
Author Topic: Denford Orac Auto Chuck  (Read 14958 times)
« on: February 09, 2008, 02:38:19 PM »
Hi, I have been using my Orac for some time now and would really like to have an auto chuck for bar feeding. I recently aquired a Burnerd collet chuck which takes the EC collet range. These are usually fitted to Colchester lathes and the outer diameter is about 5 inches and the length about 4", Fitting it to the Orac is not an issue but will I encounter other problems like the motor not capable of driving it or the force of closing the collet lever putting strain on the headstock/lathebed mountings or other issues.
Your advice greatly appreciated.
John
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Denford Orac Auto Chuck
« Reply #1 on: February 09, 2008, 03:17:13 PM »
Hi John,
in general collet chucks take less power than 3/4 jaw chucks, they run smoother and quieter,  they also need less clamping force than a 3/4 jaw chuck due to the amount of surface area covered by the collet.
Graham.
« Reply #2 on: February 09, 2008, 03:56:31 PM »
Thanks for your quick reply Graham, I was more concerned about the extra weight of the chuck compared to the 4" 3 jaw chuck the Orac has. Also the extra length of the collet chuck will be 1.5" more once I fit a backplate than the Orac chuck and I was concerned if there would be any extra load on the spindle bearings or would that not make much of a difference to worry about.
John
  •  2,785 2,785
« Reply #3 on: February 09, 2008, 09:07:21 PM »
As long as everything runs true I see no problem.
Graham.
« Reply #4 on: February 10, 2008, 08:59:28 AM »
Hi Graham, Ok Thanks for your advice.
John
