Hello Guest it is October 05, 2026, 10:16:32 PM
Author Topic: Pins and Jogging  (Read 15776 times)
Offline Keith
  •  187 187
Pins and Jogging
« on: April 28, 2006, 12:34:44 PM »
Hi,I know it's possibelt to use the pins to control jogging; is there a way to use a pin to change the jog mode('continuous' versus 'step')?
Also,is there a way to use the alloted input pins for such things as this and other things like limit switches ,in a binary mode so 5 inputs could become 32?-Keith
Re: Pins and Jogging
« Reply #1 on: April 28, 2006, 06:48:05 PM »
There is a way to make the cycle the jog types and you are going to have to use an input pin and a macropump...
There is no way to use the pins the way you were thinking... Sorry
www.newfangledsolutions.com
www.machsupport.com
Offline Keith
  •  187 187
« Reply #2 on: April 28, 2006, 07:00:11 PM »
Hmmm,so that means VB ,right? Homework... : (
« Reply #3 on: April 29, 2006, 06:11:07 AM »
There is also a way to do that with an OEM input that triggers a Macro... I have done that one time (I think), so if you et stuck I am here to help.
www.machsupport.com
