Hello Guest it is November 01, 2026, 12:18:05 PM
Author Topic: Different tool on specific layers  (Read 9477 times)
« on: February 07, 2008, 08:25:03 AM »
Mabye I am just plain stupid, but if I want to cut 2 chains/layers, example; a circle within a circle and want to use 2 different tools on this,I run in to a problem
If I choose a tool from the tooltable and set the depth and so on, and then mark the other chain to select the tool for this path, the first one changes to whatever tool I chose last.
in other words, I cannot get 2 different tools in the same project.
What settings have I got wrong?
Best reg
Cory
Re: Different tool on specific layers
« Reply #1 on: February 07, 2008, 10:28:53 AM »
Hello Cory,
I first make sure that the 2 chains are on different layers. The "Relayer" button does this for me.
Then select your tools from the "Layers" tab below. Don't click "Send to All layers" and they should stay put.
Good luck,
RC
« Last Edit: February 07, 2008, 10:31:28 AM by Overloaded »
« Reply #2 on: February 07, 2008, 03:20:11 PM »
That did the trick, Thanx RC
Best reg
Cory
