Hello Guest it is November 13, 2026, 03:35:31 PM
Author Topic: Mach3 R3.00 back to Mach3 R2.63  (Read 11934 times)
« on: February 02, 2008, 08:36:58 PM »
How come Mach3 has reverted back to Mach3 R2.63 it was at Mach3 R3.00 just a little while ago is there problems with it or something?
Thanks Mike
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Mach3 R3.00 back to Mach3 R2.63
« Reply #1 on: February 02, 2008, 09:18:34 PM »
Hi, Mike
Hears a couple comments Brian made.
Hello ,
I have taken 3.00 off the web... this version had a change that would
make files run MUCH faster BUT this is raising hell in Mach3...
The new 3.03xx revs seem to be testing well but there is still much more
Dev work that needs to be done..
If you are running 3.00 and you do not see a problem... I would run it,
it makes a much better drill cycle :) You will only have a problem with
that Rev if you are running brains and so on...
Brian
Thanks, Chip
