Hello Guest it is November 13, 2026, 09:44:53 AM
Author Topic: Index pulse on bridgeport boss 4 seris 1 2hp verry head  (Read 24774 times)
vmax549
Re: Index pulse on bridgeport boss 4 seris 1 2hp verry head
« Reply #10 on: February 03, 2008, 09:01:56 PM »
If you want the spindle speed to read out correctly, set up the pulley settings for low range and on the far right side of the setup window set the ratio to 9. Then when you select low range by the pulley setting the DRO will aply the divisor and the sprindle speed will read correctly.
