Hello Guest it is October 28, 2026, 09:22:29 AM
Author Topic: Brain and G code?  (Read 15174 times)
Brain and G code?
« on: January 25, 2008, 09:10:57 PM »
I need to put the Z axis at "g53 g0 z0"  How is that done with a brain?  Do I need to make a button and attach a VB script saying:  code "g53g0z0" and have the brain activate the button?
Re: Brain and G code?
« Reply #1 on: January 26, 2008, 10:09:16 PM »
Take what ever trigger input your using to trigger the G53 event in the Brain. Like an input or what ever.
do a no-op lobe. Send the termination to UserLED1500 (or what ever).
Then in the Macro Pump Put a If then statement. And make a custom Macro called M53
I.e.
'MacroPump
i=GetOEMDRO(2000) 'interlock counter
If GetUserLED(1500) and i=0 then 'interlock statement
Code "M53"
SetUserLED(1500,0) 'this will turn off the Brain LED even if the trigger is still on.
End If
'M53.m1s  this is the G53 macro
Code "G53 g0 z0"
While IsMoving
Wend
SetUserDRO(2000,0) 'Resets the interlock DRO in the macro pump
'Scott
