Hello Guest it is November 19, 2026, 05:46:38 PM
Author Topic: Offset in ralation to actual position  (Read 9685 times)
« on: January 25, 2008, 12:39:06 PM »
Hi. This is probably simple to do, but I am difficulty in doing it.
I want to change my currently axis position from an actual value to another in relation to the present value. Some thing like:
Actual position = actual position + 30
I normally use G92 to set a position, and in this case it would be something like
G92 X[x+30]  ???
Thank you
Re: Offset in ralation to actual position
« Reply #1 on: January 25, 2008, 01:45:59 PM »
Damm, this one was simple. A G52 would do the trick.
Should read more before I have posted.
