Hello Guest it is November 13, 2026, 09:54:11 AM
Author Topic: mode Sherline doesn't work and a loss of step is had  (Read 11844 times)
« on: January 24, 2008, 07:20:16 AM »
I have replaced the old PC with a faster and the mode Sherline  doesn't work and a loss of step is had. Can I insert in step pulse and dir pulse a great value of 5 us to obviate to the problem directly? I use motor Sanyo and cards RTA planned to 800 step for turn. Do you think that I should reduce such value to 400 step for turn or secondary LPT to add a card to resolve the problem? Is there difference among a based PC on processor AMD and one on processor Intel?
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: mode Sherline doesn't work and a loss of step is had
« Reply #1 on: January 28, 2008, 11:55:38 AM »
Have you run a driver test on your new PC? Start there and see if you get a good driver test (flat line, no big spikes).
Happy machining , Jeff Birt
