Hello Guest it is October 19, 2026, 07:54:42 AM
Author Topic: steps per 360 degree revolution.  (Read 16707 times)
« on: January 21, 2008, 10:29:54 AM »
anyone know a good formula for calculating steps per revolution.  im trying to "fine tune" my a axis.(rotating table)
thanks
dave
Offline Bodini
  •  216 216
Re: steps per 360 degree revolution.
« Reply #1 on: January 21, 2008, 11:59:33 AM »
Personal message sent to you through the Mach forum.  I dont want my half baked knowledge logged on here forever.  ;)
-Nick
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: January 21, 2008, 04:25:42 PM »
That's not on, all my craps on here  ;D
Graham.
« Reply #3 on: January 21, 2008, 06:13:40 PM »
its been a couple of years since I set mine up , but if memory serves heres how I calulated mine , 8" rotary table with servo motor, was to detirmine the ratio of the worm gear that drives it, in my case its 30 to one. 30 revolutions of the input shaft results in one full rotation of the table. I then have a timing belt (gatesXL .2 pitch) reduction  of 3 to 1. at this point it takes 90 revolutions of the motor shaft to turn the table 360 degrees I cant remember the encoder count but lets guess its a 500 cpr qaud encoder and takes 2000 pulses to move the motor shaft one revolution  . this works out to 180,000 pulse for one 360 degree revolution , 180k devided by  360 eqauls 500 steps per degree . In motor setup I just entered 500 steps per unit .
« Reply #4 on: January 22, 2008, 12:34:05 PM »
Here is how you do the math. I will give you mine as an example. What we need to know is, How many pulses from Mach will it take to move the machine 1 of your units? (inch,mm,deg.) Mine is in inches. 1 inch = 10,000 pulses on mine. This is how I came up with the number.
My steppers have 200 pulses per revolution. ( 360 degrees divided by 1.8 degrees = 200 )
Micro stepping = 10. So 200 X 10=2,000
Motor to screw gearing is 1-1. So 2,000 X 1=2,000
Screw lead is .200 of an inch. My screw will have to turn 5 rounds to move the nut 1". 1.0 divided by 0.200=5. So 2,000 X 5=10,000.
