Hello Guest it is October 20, 2026, 11:47:54 PM
Author Topic: MPG on ModBus (not ModIO)  (Read 11682 times)
« on: January 13, 2008, 06:54:43 PM »
i just get a ModBus-device to work with Mach3.
I'm able to switch any Mach3-Button by the pendant and to light any LED on my pendant.
Pots for Speed- and Feedoverride work too, but:
how get running jogging by a MPG ?
I'm using a CubLoc because ModIO was to small by In and Outs.
Has anyone tried to get MPG working on ModBus without ModIO ?
Have i to setup the MPG in Ports&Pins ?
Regards
Frank (without any idea what to do ...)
Re: MPG on ModBus (not ModIO)
« Reply #1 on: January 13, 2008, 07:57:38 PM »
Yes you can do it with Aurturos boards the M1 series
« Reply #2 on: January 14, 2008, 09:24:28 PM »
Regards
Frank,
You should have used a ModIO. ;D (Only joking)
The problem is most likely to be that you are not providing Mach with a 16 bit counter value. The counter is used to determine the how fast you are turning the MPG. Set up a counter in the Cubloc that just counts up at about 2KHz or so. Then read this in with the MPG count. Have a look at the ModIOMPG brain in Mach.
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
email: peter at homanndesigns.com
