Hello Guest it is October 21, 2026, 10:24:48 PM
Author Topic: V3.0 crash with Sleep  (Read 16682 times)
Offline Bodini
  •  216 216
« on: January 12, 2008, 09:18:46 PM »
After upgrading to v3.0, this portion of a macro code below crashed mach:
systemwaitfor (start)
While IsMoving()
Sleep 100
   Wend
g55x = getuserdro(1079) + getoemdro (800)
VB Editor opened and said the error was on the Sleep 100 line (this was part of a much longer macro).  Then VB Editor froze up and I had to reset with the button on the pc.  This happened 3 times and I re-installed v2.60... and then the problem was gone.
Yes, the macro starts off with Declare Sub Sleep Lib "Kernel32" (ByVal dwMilliseconds As Long).  Yes, I have used this macro 100's of times before with no problems in versions up to and including v2.60.
Full macro available to admin/mods.
-Nick
« Last Edit: January 12, 2008, 09:24:51 PM by Bodini »
Re: V3.0 crash with Sleep
« Reply #1 on: January 13, 2008, 05:23:25 AM »
Brian always discouraged me from using the Declare Sub Sleep.....   Dont think he  actually said why but just it was not a good way to do it. I am terrible at VB but I think I just use G4 P*** now.
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #2 on: January 13, 2008, 07:08:01 AM »
Looks like Mario had the same issue:
Yahoo forum:
http://groups.yahoo.com/group/mach1mach2cnc/message/84954
Mario
From Mach3 R3 I had the same issue. I removed the Declare sub Sleep
line from my code and it works fine. I think Art add support in R3 so
you can call Sleep without the declare.
Graham
Offline Bodini
  •  216 216
« Reply #3 on: January 13, 2008, 09:28:08 AM »
Aha, I see.  Ok, when I get a chance I will try it again with v3 and no sleep or sans the declare.  I HAD to add the sleep because Mach was blowing past the "g55x = getuserdro(1079) + getoemdro (800)" command without it.
Thanks.
-Nick
Offline Bodini
  •  216 216
« Reply #4 on: January 13, 2008, 09:30:30 AM »
Yahoo forum:
Mario
Graham
Wow, that is nearly the SAME message I posted, isn't it.  I always forget about that Yahoo message area. ;-)
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #5 on: January 13, 2008, 12:12:05 PM »
Yeah it would be great if we could all merge to one forum and have one central location. It would make thing easer to keep up with updates and changes.
« Reply #6 on: January 13, 2008, 12:52:26 PM »
Ha ha, Jason that is never going to happen. Personally I cant see the attraction of the Yahoo style groups, in fact I think they are really awkward and this style of forum is brilliant.  BUT I know there are lots of people that say exacty the opposite.
Offline Bodini
  •  216 216
« Reply #7 on: January 14, 2008, 01:46:24 PM »
Agreed 100%... and those other people are wrong. LOL. :-p
« Reply #8 on: January 14, 2008, 02:01:24 PM »
Hush now, you cant say that Art is one of the ones that prefers Yahoo :)
