Hello Guest it is November 01, 2026, 10:03:56 AM
Author Topic: Offsets not generated correctly  (Read 9178 times)
« on: January 08, 2008, 07:36:56 PM »
I am trying to generate 1/32" offsets from the attached  AcadR12 LT2 DXF file (Temp.dxf). The result I get is as shown in the attached BMP file (Offseterrors.bmp). It shows that the offsets are not continuous and are infact jumping from inside to outside. I have not had this problem before and just tried an older file and get the same unuseable result.
I know the lines are continuous ie the chain is not broken into separate segments or at least it is not broken in the DXF file, I verified this by taking the chain back into Acad and converting the line to a poly line.
I have not used LazyCam extensively but I have been able to get offsets to work in the past.
Mike
