Hello Guest it is November 02, 2026, 04:31:56 PM
Author Topic: Joining G code HELP!  (Read 14628 times)
« on: January 06, 2008, 01:19:17 PM »
HI is it possible to join together two or more G code's if so can anybody help . i use Lcam to produce my code.
thanks Rob.
Offline docltf
  •  354 354
Re: Joining G code HELP!
« Reply #1 on: January 06, 2008, 02:34:17 PM »
use copy and paste with your text editor.it is not fancy but works real good.
« Reply #2 on: January 06, 2008, 02:37:59 PM »
HI docltf
 is it as easy as that .Thanks
Rob
« Last Edit: January 06, 2008, 04:53:45 PM by RobWilson »
Offline docltf
  •  354 354
« Reply #3 on: January 06, 2008, 04:01:23 PM »
YEP
leave some space between old and new so you don't get lost.
edit out what you don't want add what you want.
engage warp drive and machine away!
« Reply #4 on: January 06, 2008, 04:52:06 PM »
hi docltf
i have given it ago and mach3 dose not see the second part . no warp drive, what do i need to edit
Rob
« Last Edit: January 06, 2008, 04:55:54 PM by RobWilson »
Offline docltf
  •  354 354
« Reply #5 on: January 06, 2008, 05:44:22 PM »
rob
take the code that you have combined as a text file and post it as an atachment to the forum so we can download it and look at it.
another thing i should mention is their is a nesting wizard under the wizards in mach if you need to do somthing like that too.
bill
« Reply #6 on: January 07, 2008, 11:03:31 AM »
Hi Bill
here is the file. mach only See's the first part.i found the nesting wizard i will have ago with it.
thanks rob
« Last Edit: January 07, 2008, 11:08:23 AM by RobWilson »
Offline TonyP
  •  132 132
« Reply #7 on: January 07, 2008, 01:09:58 PM »
Rob,
the first section has M30 as the final code (N89) This is program end & rewind. Take the first one out & the code should carry on to the second section.
Tony
« Reply #8 on: January 07, 2008, 02:52:45 PM »
Hi Tony
 removing M30 did the trick .I am new to cnc and  will have to read up the section on code in the mach 3 manual.
Thanks for your help Bill and Tony .
Rob
