Hello Guest it is November 27, 2026, 02:55:56 PM
Author Topic: Asigning a 4th linear axis ?  (Read 16377 times)
ynneb
« on: April 23, 2006, 10:39:06 PM »
If I asign a rorary axis as a 4th linear axis will it behave the same as a liner axis when jogged.
The machine it will be used on is for a hot wire foam cutter. They have two X and Y axis, one on  the left and right hand side.
From what I gather, the machine is manually driven instead of g-code driven ( I think )
My question is, if I asign a rotary axis for the 4th axis, ( This is the only option I have) will the DRO display the same as a linear axis?
Make sense ?
« Last Edit: April 23, 2006, 10:42:09 PM by ynneb »
Re: Asigning a 4th linear axis ?
« Reply #1 on: April 24, 2006, 05:58:04 AM »
No problem ! This will work great....
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: April 24, 2006, 02:22:29 PM »
Sorry Benny for hijacking this thread,
I have a similar question on the Z axis.
The Quill axis on my knee mill (Chinese) is not as good as the Knee axis (both Z)
So in manual times I tend to use the Knee rather than the Quill just to make sure.
So in Mach how would I define Z and Z1 ?
Is the 4th axis used for this ?
Needles to say the axis work in opposite ways
JB
« Reply #3 on: April 24, 2006, 05:43:14 PM »
I would set it up as the C axis... and you should be good to go...
www.machsupport.com
