Hello Guest it is November 01, 2026, 11:53:01 AM
Author Topic: cut direction cant be changed  (Read 29476 times)
Re: cut direction cant be changed
« Reply #10 on: September 14, 2008, 08:11:08 AM »
Here is the lcam file.
DXF was only single layer.
« Reply #11 on: September 14, 2008, 08:12:02 AM »
How about posting the dxf Brian?
« Reply #12 on: September 14, 2008, 08:15:32 AM »
Just put up the lcam.
here's the dxf.
« Reply #13 on: September 14, 2008, 08:22:57 AM »
Thanks Brian,
I opened your dxf in ProgeCad and did nothing to it, just saved it as a AutoCad 12 type file and then opened it up in LCam.
I'm not having the issue you're having as you can see below. I think your problems with LCam are definitely with your files that are being drawn.
« Reply #14 on: September 14, 2008, 11:00:37 AM »
I totally disagree.
I imported this file in Sheetcam, Autocad, corel X-4 , mastercam, and visual mill.
All had no problems.
When LCam writes the Gcode for the profile, it's perfect.
just when I free rotate with the wheel of the mouse it gets funky.
Look at the pic below
Brian
« Last Edit: September 14, 2008, 11:08:25 AM by KNS Supply »
« Reply #15 on: September 14, 2008, 11:28:52 AM »
Oh I'm not doubting you at all, Brian, I'm just saying that for LazyCam in particular, it doesn't like your files.
Not saying your files are wrong, just wrong for LazyCam - ;)
For some reason with ProgeCad, it works very nicely.
Offline docltf
  •  354 354
« Reply #16 on: September 14, 2008, 01:05:01 PM »
kns
uninstall that copy of lcam, reboot, download a fresh copy.
post your computer specs, and is your video card built on the motherboard.
bill
