Hello Guest it is October 11, 2026, 12:38:24 AM
Author Topic: Using external inputs and OEM codes  (Read 13288 times)
Offline rkd
  •  4 4
« on: January 03, 2008, 02:46:30 PM »
Hi, I ahve a question about assigning oem codes to external pushbuttons.  I currently am using 2 pushbuttons for the pause/freehold and the resume functions.  I was able to find the codes for those on the wiki.  My question is how do you set up an external button for a function that doesn't have an OEM code assigned to it in the wiki?  ie.  I am using a script with an on-screen button for a z-zero routine and would like to be able to access that function from a pushbutton at the machine itself.  I did a search through the wiki and found that code 301 is used somehow but i can't figure out how to assign it to my input.
Thanks, Ryan
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Using external inputs and OEM codes
« Reply #1 on: January 03, 2008, 09:08:34 PM »
Hi, Ryan
I think you need to set an oem trigger up, In ports and pin's, Inputs, To a OEM trigger # (1-15) for your switch.
Then include that triggers oem code in your script, something sorta like this.
If IsInputActive( OEM Trig # ) Then
   DeActivateSignal( OEM code )
Else
End If
Well it's a Start, Chip
« Reply #2 on: October 12, 2008, 12:51:12 PM »
Hi Chip,
can you elaborate on that.
Thanks.
Offline Chip
  •  2,055 2,055
« Reply #3 on: June 05, 2004, 03:55:15 AM »
Hi, Cnceer
Looking at PM you sent me.
Is it a Script issue ?
If your trying to Zero the Z axis Dro with a external  button,
Hears two screen shots that should help,
Set for pin 10, trigger 1, Gnd pin 10 to Zero Z (OEM 1010).
Hope this Helps, Chip
