Hello Guest it is November 01, 2026, 10:04:01 AM
Author Topic: LazyCam 3.00.2  (Read 13371 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
LazyCam 3.00.2
« on: January 03, 2008, 01:33:13 PM »
Hi, Brian
Happy New Year to All, OK, So I'm a few day's late on this, Hope the transition is going well.
Seeing your doing a little work on LC, Hears a few issues that are still hiding in Offsetting and Pocketing,In, Mill, Plasma, Foam.
I've tried this DXF in many way's/formats, grouped, un-grouped, exploded and saved with different cad program's, TurboCad V 8, BobCad V 22, Rino.....
Over different Ver's of LC it's worked from time to time, Hears the DXF and some screen shot's
Thanks, Chip
« Last Edit: January 03, 2008, 02:06:36 PM by afn09556 »
Offline Chip
  •  2,055 2,055
Re: LazyCam 3.00.2
« Reply #1 on: February 03, 2008, 05:26:06 PM »
Hi, Rich
Downloaded your files, The Dxf doesn't seem to work any better hear.
Thanks, Chip
Offline docltf
  •  354 354
Re: LazyCam 3.00.2
« Reply #2 on: February 03, 2008, 10:00:02 PM »
CHIP
Did you forget the Question ?, Chip
« Last Edit: February 03, 2008, 10:12:28 PM by Chip »
Offline docltf
  •  354 354
Re: LazyCam 3.00.2
« Reply #3 on: February 03, 2008, 10:20:50 PM »
Ha hit the wromg button!
CHIP
    as good as your drawing is l-cam will have a hard time.attached are two files made from your dxf . i ran them through l-cam 3.00.2 and mach3  3.00.this is how i dit it to trick l-cam.
    i imported your dxf into l-cam.
    hit the scale  button just to move the origin but not to change the scale.
    picked a tool for the layers,and set the tool for the code.
    generated g-code and sent it to mach3.
    imported g-code into l-cam from mach3.
    then i hit the optomize button.
    saved drawing as l-cam file.
    now you can play with it.  another thing i noticed with l-cam is if you box a drawing with a chain it will help when you do things to the drawing ,then delete the box chain.
  bill
Offline Chip
  •  2,055 2,055
Re: LazyCam 3.00.2
« Reply #4 on: February 03, 2008, 11:39:38 PM »
Hi, Bill
Now that worked really really Nice, Have worked with LC for quite awhile, Don't think I tried that for a cleanup routine.
Thanks, Chip
