Hello Guest it is November 23, 2026, 12:47:26 AM
Author Topic: I can't edit the values in any of the wizards?  (Read 82137 times)
« on: April 22, 2006, 12:23:41 PM »
I've got the latest download of Mach3 and it's working great and I can load up the wizards but any attempt to change the values in the wizard (like for setting the radius of the circle cutting wizard) results in the value getting reset back to it's default after I've left the edit field.
Offline Bloy
  •  158 158
Re: I can't edit the values in any of the wizards?
« Reply #1 on: April 22, 2006, 07:41:33 PM »
after changing a value, hit "enter" to make it stick.  If you want to save all your settings in a wizard, click "save settings" before closing.
« Reply #2 on: April 22, 2006, 08:31:29 PM »
Thank you.  ;D
