Hello Guest it is November 01, 2026, 10:01:36 AM
Author Topic: Need help for circle milling  (Read 9305 times)
« on: December 29, 2007, 02:18:08 AM »
Hello All,
i have problem with circle milling ! I am totaly newbee in CNC
i use a mill with diameter 1.778mm but the hole is to big,
and dont fit to my dxf. I choose a adapt leading settings.
i send you the lcam file, i hope somebody can help me!
Fabrice
Re: Need help for circle milling
« Reply #1 on: December 29, 2007, 07:27:37 AM »
Hello
i search and found that it a problem with the offset tool. When i indicate in Mach 3
the size of the mill (offset tool) the cnc mill the right size.
I a a little bit dissapoint because i had understand that lazy cam normaly
make the right compensation for the tool and not mach 3.
is that so ?
Fabrice
« Reply #2 on: December 31, 2007, 08:44:26 AM »
i continue to search and found the options G41 G42 in the post gcode
fontion to Mach3.
It is much better now, the offset of the tool is take in consideration.
I will continue to learn...
Happy new Year,
Fabrice
