Hello Guest it is October 13, 2026, 03:32:18 PM
Author Topic: How do I reset to 0 degrees 4th axis without unwinding?  (Read 10964 times)
Offline Haik
  •  71 71
  • MachUser
« on: December 28, 2007, 03:41:10 PM »
Hello Forum,
I have a to repeat a process several times that involves my 4th (or A) axis.  What's the best/easiest way to reset to 0 degrees 4th axis without unwinding between operations?
Also, can that be automated to run from gCode?  Thanks!
Offline docltf
  •  354 354
Re: How do I reset to 0 degrees 4th axis without unwinding?
« Reply #1 on: December 28, 2007, 11:55:41 PM »
i believe you use G92
go through your code and where you want it to reset at try this
G00 G92 A0
Offline Bodini
  •  216 216
« Reply #2 on: December 31, 2007, 03:44:17 PM »
Agreed.
G92 A0
Offline Haik
  •  71 71
  • MachUser
« Reply #3 on: December 31, 2007, 04:37:20 PM »
Perfect!  Thanks docltf and Bodini.
-Haik
