Hello Guest it is October 20, 2026, 07:02:05 PM
Author Topic: Version 3 stepper problems  (Read 9718 times)
« on: December 27, 2007, 11:01:22 AM »
Can anyone help. I have been running version 2.040 for 9 months on my bridgeport mill
with no problems at all. I remember trying to upgrade to version 2.065 and now version 3
and have encountered the same problem.
When i try to jog any of the 3 axis all is well until i try to change direction. At this point the steppers
slow down, stop and then accelerate slowly up to the feed i have set. If i stop and then jog in the
same direction all is well but if i reverse the direction the same thing happens.
Is there a setting I have missed? I am running windows 2000 sp4
regards
Ian Garner
Offline TonyP
  •  132 132
Re: Version 3 stepper problems
« Reply #1 on: December 27, 2007, 03:03:01 PM »
Sounds like the backlash compensation is turned on & not set correctly. I've had something similar after an upgrade.
Tony
« Reply #2 on: December 27, 2007, 04:39:00 PM »
 :D
Thanks for the info. I have looked at the backlash topics and changed the general config - shuttle accel setting from 1 to 0.1 seconds
and now everything works fine.
Many thanks
 Ian
