Hello Guest it is October 20, 2026, 07:55:43 PM
Author Topic: No output signal  (Read 9448 times)
No output signal
« on: December 26, 2007, 12:31:07 PM »
Powered up system for first time. All 5 volt power from transformer and usb working fine. Hooked up drives as per instructions regarding setting com to 5 volts on a C1 board from CNC4PC. Tested drives with self test and they work. My home and limit signals work, as the leds go on and off when I activate these switches. I get no power (leds do not light ever) from my outputs. I am using Mach3 software and have verified my parallel port. I have the X,Y and Z enabled and on low active, but I get nothing when I try to tune the motors. When I power up the system I get a thump on each motor, like locking into place. Can anybody offer any help?
Re: No output signal
« Reply #1 on: December 27, 2007, 05:11:44 PM »
Solved my own problem. Bad cable.
