Hello Guest it is November 07, 2026, 11:17:26 AM
Author Topic: lazycam in turn mode  (Read 9593 times)
Offline Don C
  •  26 26
« on: December 25, 2007, 11:08:04 AM »
 How do you get lazycam to cut a profile in more than one pass?
  Don
Offline TonyP
  •  132 132
Re: lazycam in turn mode
« Reply #1 on: December 26, 2007, 10:07:19 AM »
Don
If you make sure that there is a line at the RHS of the stock extending to the outer diameter of the stock, Lcam will use several cuts, depending on the roughing & finishing settings to produce the profile. I'm not an expert - but that's what I've found. There's not much information about using turn yet, also it doesn't always do what you want. Bear in mind it's still work in progress.
Tony
Offline TonyP
  •  132 132
« Reply #2 on: December 26, 2007, 11:06:30 AM »
To clarify the last post, the line needs to extend from the centre of the stock to the OD. A separation of 0.5mm will do. You also need to join the lines at the centre, so its one continuous line on the same layer.
I've attached a simple example.
Tony
