Hello Guest it is November 23, 2026, 12:25:51 AM
Author Topic: OK that does it!  (Read 63335 times)
Offline Whacko
  •  239 239
  • Happy Days
Re: OK that does it!
« Reply #10 on: December 25, 2007, 04:02:36 PM »
I'll have to get back to you a bit later, entertaining a sloshed family memeber
Whacko
Nothing's impossible
« Reply #11 on: December 25, 2007, 04:29:49 PM »
YEAH............I'VE GOT SEVERAL MYSELF. FIRST THINGS FIRST.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #12 on: December 25, 2007, 06:09:29 PM »
In the G76 cycle the L word is the one that controls the exit angle, try L90 and a slow speed, 200 RPM, you may be able to go faster but it depends on the speed of your system.
Graham.
« Reply #13 on: December 25, 2007, 09:14:46 PM »
As mentioned earlier, I tried various L angles. 0,30,45 and 60 deg. with no difference. The manual says L is optional so rather than leaving it out of the line I just put L0 assuming that would be the same as no entry. I'll try L90 tomorrow and slow it down a bit.
I hope I don't have to slow it too much just to get it to pull out right. Everything else is perfect at 700-800 rpm.
RC
  •  2,785 2,785
« Reply #14 on: December 26, 2007, 04:13:13 AM »
If you think about what's happening here, you are asking the tool to feed out of the thread in 1/4 of a turn of the thread.
If you are running at 750 RPM that is 12.5 revs per second, that means the tool has to get out of the thread in 0.02 seconds. Not in my life time  :o.
That is why it has to run sllloooowwww.
Graham.
« Reply #15 on: December 26, 2007, 05:09:25 AM »
Ahhhhhhh..........YES. Now that you put it that way, it makes a lot of sense.
That would be asking a bit much at high rpm.
Hopefully, the groove will be acceptable.
Thanks Graham,
RC
  •  2,785 2,785
« Reply #16 on: December 26, 2007, 05:19:23 AM »
Graham.
« Reply #17 on: December 26, 2007, 08:50:03 AM »
Graham,
This is strange to me...when I put in L90, the threading cut started in the opposite direction...towards the tailstock and kept on all the way to the Z+ limit. Entry <90 works OK.
Is this normal ?
RC
  •  2,785 2,785
« Reply #18 on: December 26, 2007, 10:15:03 AM »
That's a new one to me, I have asked Art for comments.
Graham.
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #19 on: December 26, 2007, 12:09:49 PM »
Hi Graham:
  The G76 is actually a macro M1076.m1s located in the Mach3 folder. Ill ask Brian to add
that to his list, I suspect the math falls apart at 90 degrees . I suspect the math is falling apart over 89..
Art
