Hello
Guest
it is
October 21, 2026, 06:08:17 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Mach 2 Height Control
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach 2 Height Control (Read 21677 times)
cfm
on:
November 22, 2005, 08:35:18 PM »
I can't seem to adjust the height at which the plasma cutter is, moving it left/right or up/down is fine, but i need to lower it a bit, and can't seem to do it.
can anyone help?
thanks
Brian Barker
3,860
Re: Mach 2 Height Control
Reply #1 on:
November 23, 2005, 05:40:22 PM »
There are a few ways to move the plasma up and down. IF it is when it is cutting you can use the torch up / down inputs. OR if you just need to move it and it is set up as the Z axis you can use PGUP and PgDn.
Very sorry if that is not what you are looking for
Hope that Helps
Brian
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
