Hello Guest it is November 10, 2026, 06:42:39 PM
Author Topic: Home and Limit Switches ... I'm Going Crazyyyyyyyyy!!!!!!!!!!!!  (Read 58362 times)
Re: Home and Limit Switches ... I'm Going Crazyyyyyyyyy!!!!!!!!!!!!
« Reply #10 on: December 15, 2007, 04:21:17 AM »
edit: Hood posted while I was composing - looks like we're thinking similarly :)
ahhhhhh but that now poses another question, is it a case of
Great minds think alike
or
Fools seldom differ
:D
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #11 on: December 15, 2007, 04:25:23 AM »
I'd like to think it's the former, but then if I'm the latter, I would wouldn't I?  ;D
« Reply #12 on: December 15, 2007, 05:14:23 AM »
well I am definitely the latter :D
« Reply #13 on: December 15, 2007, 05:21:26 AM »
I say, in the case of you two, Great minds think alike  ;D
« Reply #14 on: December 15, 2007, 05:46:51 AM »
nah that cant be right, because I often agree with you Brett :D
« Last Edit: December 15, 2007, 10:30:54 AM by Hood »
Offline stirling
  •  2,188 2,188
  • UK
« Reply #15 on: December 15, 2007, 08:21:29 AM »
I was always taught to accept a compliment with good grace - so cheers Brett - a man of rare insight I believe ;D
« Reply #16 on: December 17, 2007, 01:36:16 PM »
This is connected to another problem at this thread, http://www.machsupport.com/forum/index.php/topic,5189.0.html
Anything will help
Bill
« Reply #17 on: December 17, 2007, 02:19:01 PM »
I would disconnect all your limits and just connect up one, but still have all the limits set up in Ports and Pins like you have already.
 Have it so you can activate it by hand and do the homing sequence. Once the Z starts to home press the switch and Mach should stop and start to reverse, when it starts reversing release the switch and it should stop and the Y axis should start, just repeat the procedure for the Y and then the X.
 If this works OK then you need to look at either your wiring or the way the switches are activated, but we will cross that bridge if you get it working with one switch.
« Reply #18 on: December 17, 2007, 02:57:23 PM »
Wise words Hood.  :)
« Reply #19 on: December 17, 2007, 04:38:47 PM »
All,
Ok, I will give that a try, stirling also suggested that I hook up the X, Y, and Z on 3 separate pins, split them up. I Will give it a go as soon as I get home from work.
Thanks Again
Bill
