Hello Guest it is November 11, 2026, 11:00:32 AM
Author Topic: wizard  (Read 10564 times)
wizard
« on: December 10, 2007, 03:31:54 PM »
hi,
is there an easy way to chain several wizards together to make a complete part (lathe)? or is there a third party plugin that will do something similar, like a recorder? if not, is it possible for me to program one and integrate it into mach3?
Re: wizard
« Reply #1 on: December 10, 2007, 03:51:43 PM »
No way apart from cutting and pasting the code from several wizards to make a full programme up. You could however if you are good with VB write your own and and I think you would just need to place it in the addons folder for it to work.
Re: wizard
« Reply #2 on: December 11, 2007, 10:10:17 AM »
Yes, Brians jog learn plug in will record your moves and then play it back for you........
