Hello Guest it is November 11, 2026, 11:00:30 AM
Author Topic: Keygrabber  (Read 13131 times)
Offline wdp67
  •  31 31
Keygrabber
« on: December 04, 2007, 08:09:04 PM »
Anybuddy willing to help me with keygrabber? Are there any instructions anywhere.
Walt
Re: Keygrabber
« Reply #1 on: December 04, 2007, 10:10:58 PM »
Hi Walt,
    I'll help what I can.
Offline wdp67
  •  31 31
Re: Keygrabber
« Reply #2 on: December 05, 2007, 11:40:52 AM »
Thanks Brett
I will have to wait till this evening when I get home but I could sure use some help, I have been playing with a game pad, but something is wrong, sometimes it works sometimes it doesnt, and I need help programing the buttons. I will see if your on line when I get home.
Walt
Re: Keygrabber
« Reply #3 on: December 05, 2007, 12:45:30 PM »
Sounds good walt. I'll be in and out this evening so we should catch up with one another sometime. You may also want to look at this thread too.
http://www.machsupport.com/forum/index.php/topic,1391.0.html
Offline wdp67
  •  31 31
Re: Keygrabber
« Reply #4 on: December 05, 2007, 07:37:40 PM »
Ok home at last, I read your post but still need some guidance. I have a gam pad with 13 or 14 buttons, 2 joystix and a multi directional pad. I played around with it months ago and had a few things working, but know it seems that sometimes it works sometimes it doesnt. I only had it semi working before from trial and error, so a quick tutorial may be needed. Tonight when I got home I tried this:
opened keygrabber, started mach from there. loaded a program and hit the run button and it started working. hit the feed hold button it did nothing, hit the stop same thing. looked at keygrabber and it seems like those three buttons are set up right but I can not get them to do anything. I continued fiddling with it and then keygrabber locked up and everything crashed.
Walt
Re: Keygrabber
« Reply #5 on: December 05, 2007, 08:27:23 PM »
I have sent you a personal message.
