Hello Guest it is November 13, 2026, 07:59:07 PM
Author Topic: When I use the Multi Pass wizard I get a random loss of position.  (Read 13003 times)
Ok, so I’m running Mach 3 with a MicroMill 2000. When I use the Multi Pass wizard I get a random loss of position. ( .180 inches out in the  X)  I have gone thru the optimization and have done everything there. I ran fine for two hours and then BOOM. It pauses for a second and when it starts back up I’m out of position.  Any suggestions????
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: When I use the Multi Pass wizard I get a random loss of position.
« Reply #1 on: December 02, 2007, 09:13:15 PM »
Hi, George
Was there any statement in the Status: window ?, Or did it start back up on it's own ?, Any other Program's Running ?
Post the G-code use the REPLY Button and Attach.
Thanks, Chip
« Reply #2 on: December 03, 2007, 03:26:14 AM »
      I didn't notice any Statement.   It was cutting fine , it paused for about 3 seconds and then started cutting by itself, but it was then way out of position. . The only other program ,to my knowledge was Lazy-Cam. I had this problem earlier so I went to the website and read the optimization info and made sure I followed those instructions. So far this only seems to happens when I use MULTI PASS.
« Reply #3 on: December 03, 2007, 03:30:10 AM »
Ok.
    It happened again  The Status Line says  " Nothing to Feedhold"
« Reply #4 on: December 03, 2007, 06:31:10 AM »
Ok Here is the file
« Reply #5 on: December 04, 2007, 06:02:58 PM »
Try using a different keyboard.
