Hello Guest it is September 16, 2026, 08:35:46 PM
Author Topic: Problem Slaving 2 Axes  (Read 34925 times)
« on: November 26, 2007, 02:24:14 PM »
Hello,
I was wondering if you could help me with a problem I am having or send me in the right direction. I have a foamlinx CNC hotwire and I am trying to set it up using mach 3. I will only be cutting 2d parts so I can use basic g-code. I am trying to slave the X-axis to the A and the Y-axis to the B. It will not let me slave 2 axis at one time. Only one or the other works. I just need both X-axis to move together as well as the Y-axis. Do you know how I could do this? Thank you for your time.
