Hello Guest it is October 18, 2026, 11:37:22 PM
Author Topic: Machpro delay when changing direction during machining  (Read 86 times)
« on: October 17, 2026, 11:22:12 PM »
Hi
I've noticed that during interpolating a bore, as an example, at each 90 degree point there is a momentary delay in the processing that is causing a minimal undercut within the bore.
This is with ESS as the motion controller and a well speced PC running Machpro.
Anyone have any ideas as to cause?
Phil
Re: Machpro delay when changing direction during machining
« Reply #1 on: October 18, 2026, 09:55:19 AM »
Could this be due to running in Exact Stop mode (G61) versus Constant Velocity mode (G64)?
Steve Stallings
www.PMDX.com
« Reply #2 on: October 18, 2026, 01:46:24 PM »
Yep, I noticed that the active modals showed G61 just after I posted the question.
My POST was not adding a G64 so I've modified it to do so.
I think that will fix it.
Phil
« Reply #3 on: October 18, 2026, 07:38:22 PM »
Made the change and ran a test file.
All is good now.
I didn't expect that MachPro would not by default set G64
Phil
« Reply #4 on: October 18, 2026, 07:47:17 PM »
I do not have a MachPro system to check, but I suspect that there is a place in your config where you can set the defaults for mode setting G codes.
« Last Edit: October 18, 2026, 07:50:55 PM by Steve Stallings »
Steve Stallings
www.PMDX.com
