Hello Guest it is November 15, 2026, 06:15:56 AM
Author Topic: Perfect DRO block.  (Read 119485 times)
Perfect DRO block.
« on: September 20, 2026, 01:45:02 AM »
I am moderately frustrated that the Axis Position Group, which I have long called the DRO block on the main (Gcode) page/tab
is not editable.
Today however I was fiddling around with the Tool page/tab, and on that page is the essetially similar DRO block, but in this case there is
a <ZeroAxis> button alongside each DRO. Also, the numeric content of the DRO is editable, for example; 'double-click and divide by two.
If the <DRO_AutoCalc> function is instantiated, then it's possible to do mathematical manipulation of the numeric content of the DRO.
This is exactly what I'm looking for, it behaves almost identically to the DRO block in Mach4.
Is it possible to call this particular hard coded DRO block into the main (Gcode) page?
99% of my work with my current Mach4 setup is done just on the main page, I very seldom need to view other pages/tabs, and I now
realize that it is the functionality of the DRO block that gives the most productivity gains. For this purpose, the DRO block of the Tools tab
is much preferred.
Re: Perfect DRO block.
« Reply #1 on: September 29, 2026, 11:53:36 AM »
The easiest method, if you wish to have that, is to have a button on your widget called Edit Offsets.
You can have Edit Offsets toggle, Edit Offsets On, Edit Offsets Off. You will probably want Toggle or on.
To change this, Right click on the Widget below your DRO's → Select Configure Widget → Select "Change" on the button you want to have the button assigned to your command → Select Edit Offsets <Type> → Ok → Save.
This should give you the Edit DRO's you wish to have on the main GCode page.
You may run into the case of the text on the buttons disappearing on save, simply restart mach and the text will repopulate.
Paul
« Reply #2 on: September 29, 2026, 02:08:15 PM »
Hi Paul,
you may think its easiest to have a widget button......I do not!
I've had twelve years operational experience, six of those years daily, with a DRO block with a <Zero Axis> button alongside and be able to edit the DRO numeric content
thereby imposing what amounts to a coordinate shift. It works in Mach4, and at least in the Tools tab of MachPro it works as well. What I want is THAT DRO block
to be instantiated on the main Gcode tab of MachPro.
Over the last few days I've been working my machine hard and I've been taking particular note of those functions and features that I use often, and those that I seldom if ever use.
Top of that list is the DRO block I have described. I want and need it top-dead center all the time.
Next on that list is <GoTo Work Zero>, I use it a lot for touching off and am frustrated that it is unreliable at best in MachPro.
Another thing that I use a lot is Speed edit. If I am doing any manual or MDI type machining I routinely type into the Spindle speed DRO and hit <Enter> This has always worked
in Mach4, but not so in MachPro. You type in a number and sometimes it might stick and the spindle respond accordingly, but mostly MachPro repopulates the speed DRO with what
'it thinks' it should be. Hugely frustrating. You might say use the spindle speed slider.....but I don't want or need the spindle speed slider, I can and do determine the spindle speed
to effect the operation I'm attempting, I type it in and hit<enter>........thats it. Pretty damned simple. I want and need the MachPro spindle speed DRO to replicate that edit authority
that I have in Mach4.
My machine in standard tune is capable of 15m/min in all axes. That is itself de-tuned from the 25m/min that its capable of. In 95% of my operating I find even 15m/min too aggressive,
so in normal operating condition I select the RRO (Rapid Rate Override) to 50%, thus bring the g0 rapids down to a manageable 7.5m/min. Only when I have long tool paths especially if it entails
many g0 moves do I up the ante to 15m/min. Thus my preference for MachPro is jus simply two buttons, or maybe just one toggling button, i.e. 50% or 100%. Is it possible to
edit the functionality of the RRO?
Last thing (gripe/wish) is that on the right hand widgets panel I have a manual jog block, and until I get my wired pendant running properly I'll have to rely on it heavily, but the good news is that
it works perfectly. What dies rather concern end even frighten me on several ocassions is when I first fire up MachPro the jog speed is autmatically 100%. To jog at that speed is to break things.
If you use the slider then you can reduce the jog speed to say 5% (comfortable) or 10% (fast but without being frightening), and thereafter everything is fine. Is it possible to set the defualt setting
of the jog speed slider to 10% say?
« Reply #3 on: September 29, 2026, 05:28:13 PM »
With this, we will have to address it pragmatically as we do not have pre-canned options for doing this. We do it this way to prevent operators from accidentally hitting the a zero when they do not mean to. Use the following code in your UserGUIModule. It should function like you want. This code will address your Edit Offsets..
Code: [Select]
-- Always-On Edit Offsets
-- INTENDED FOR SINGLE-INSTANCE MACH CONFIGURATIONS.
-- Policy:
--   Edit Offsets ON whenever Mach is Idle.
--   Edit Offsets OFF whenever Mach is not Idle.
--   Do not fight the Cycle Start sequence while it intentionally
--     turns Edit Mode off.
--   If Mach or the operator turns Edit Offsets off while Idle,
--     restore it automatically.
-- Preserve existing OEM / inherited callbacks.
local PreviousScreenIsLoadedScript =
    UserGUIModule.ScreenIsLoadedScript
local PreviousMachStateChanged =
    UserGUIModule.MachStateChanged
local PreviousPostScreenTabEnter =
    UserGUIModule.PostScreenTabEnter
local PreviousUserPLCScript =
    UserGUIModule.UserPLCScript
-- State
local PendingEditModeEnable = false
local EditModeWatchdogTimer = wx.wxStopWatch()
local EDIT_MODE_WATCHDOG_MS = 250
local MultiInstanceWarningLogged = false
-- CallPreservedCallback
-- Runs an OEM / inherited callback that existed before this module
-- replaced the exact callback name.
function UserGUIModule.CallPreservedCallback(callback, ...)
    if callback == nil then
        return true, true, nil
    end
    local is_ok, a, b, c =
        w.pcall(callback, ...)
    if not is_ok then
        return nil, false,
            w.FunctionError(w.ErrorMessage(a))
    end
    if b == false then
        return a, false,
            w.FunctionError(c)
    end
    if a == false then
        return false, b, c
    end
    return true, true, c
end
-- IsAlwaysOnEditModeSupported
-- CommonScreenV02.EditModeOn() checks the global MACH_STATE, which
-- represents instance 0.
-- Because of that Common implementation, this policy is deliberately
-- disabled when more than one Mach instance is configured.
function UserGUIModule.IsAlwaysOnEditModeSupported()
    if w.GetInstanceCount() ~= 1 then
        if not MultiInstanceWarningLogged then
            w.Log(
                "Always-On Edit Offsets disabled: "
                .. "CommonScreenV02.EditModeOn uses the instance-0 "
                .. "MACH_STATE global and is not selected-instance safe."
            MultiInstanceWarningLogged = true
        end
        return false
    end
    return true
end
-- ApplyAlwaysOnEditMode
-- Central policy function.
function UserGUIModule.ApplyAlwaysOnEditMode()
    -- Do not claim multi-instance support that CommonScreenV02
    -- cannot provide.
    if not UserGUIModule.IsAlwaysOnEditModeSupported() then
        return true, true,
            "Always-On Edit Offsets skipped for multi-instance configuration"
    end
    local inst = 0
    -- Determine the real current idle state from Mach's output
    -- signal rather than depending on the cached MACH_STATE global.
    local idle, b, c =
        w.GetSignalState(
            mc.OSIG_MACHINE_IDLE,
            inst
    if b ~= true then
        return nil, false,
            w.FunctionError(c)
    end
    -- IDLE
    if idle then
        -- Cycle Start deliberately turns Edit Mode off while its
        -- startup sequence is running.
        -- Do not fight that sequence.
        if w.FuncTracing["m.CycleStart"] == true then
            PendingEditModeEnable = true
            return true, true,
                "Edit Offsets enable deferred during Cycle Start"
        end
        -- Already active -- nothing to do.
        if m.screen.IsEditModeActive() then
            return true, true,
                "Edit Offsets already active"
        end
        -- Ask the normal Mach screen to enable Edit Mode.
            w.pcall(m.screen.EditModeOn)
        if not is_ok then
            local msg = string.format(
                "Unable to automatically enable Edit Offsets: %s",
                w.ErrorMessage(a)
            w.Log(msg)
            return nil, false,
                w.FunctionError(msg)
        end
        if b == false then
            return a, false,
                w.FunctionError(c)
        end
        -- EditModeOn can return success even when its MACH_STATE
        -- check prevented activation.
        -- Verify the actual GUI state before logging success.
        if not m.screen.IsEditModeActive() then
            return true, true,
                "Edit Offsets enable deferred"
        end
        w.Log(
            "Edit Offsets automatically enabled: machine is Idle"
    -- NOT IDLE
    else
        -- If already off, nothing is required.
            return true, true,
                "Edit Offsets already inactive"
        end
        -- Turn Edit Mode off immediately whenever motion/state
        -- leaves Idle.
            w.pcall(m.screen.EditModeOff)
        if not is_ok then
                "Unable to automatically disable Edit Offsets: %s",
                w.ErrorMessage(a)
            w.Log(msg)
            return nil, false,
        end
        if b == false then
            return a, false,
                w.FunctionError(c)
        end
        -- Verify that the screen actually changed state before
        -- reporting success.
            return nil, false,
                w.FunctionError(
                    "Edit Offsets remained active after EditModeOff"
        end
        w.Log(
            "Edit Offsets automatically disabled: machine is not Idle"
    end
    return true, true,
        "Always-On Edit Offsets policy satisfied"
end
-- ScreenIsLoadedScript Hook
-- Apply the policy once the normal screen startup has completed.
function UserGUIModule.ScreenIsLoadedScript()
    -- Preserve inherited / OEM behavior.
    local a, b, c =
    if b ~= true then
        return a, false, w.FunctionError(c)
    end
    if a == false then
        return false, b, c
    end
    -- Start the watchdog timing from a known point.
    EditModeWatchdogTimer:Start()
    -- If this is multi-instance, log the limitation and leave the
    -- normal Mach behavior untouched.
        return true, true, w.FunctionCompleted()
    end
    -- Startup normally occurs after the Mach state globals are
    -- valid, so try immediately.
    -- If EditModeOn declines because state initialization is still
    -- settling, ApplyAlwaysOnEditMode sets PendingEditModeEnable
    -- and the PLC callback will retry.
    local pa, pb, pc =
    if pb ~= true then
        return pa, false, w.FunctionError(pc)
    end
end
-- MachStateChanged Hook
-- IMPORTANT:
-- CommonGUIModule invokes this hook BEFORE it updates the global
-- instance-0 MACH_STATE.
-- Therefore:
--   Going NON-IDLE:
--       Disable Edit Mode immediately. This path does not depend on
--       EditModeOn's MACH_STATE check.
--   Going IDLE:
--       Set PendingEditModeEnable and let UserPLCScript enable Edit
--       Mode later in the SAME PLC pass, after MACH_STATE is current.
function UserGUIModule.MachStateChanged(inst, state)
    local a, b, c =
            PreviousMachStateChanged,
            inst,
            state
    if b ~= true then
    end
    if a == false then
        return false, b, c
    end
    -- This implementation intentionally supports instance 0 only.
    end
    if inst ~= 0 then
    end
    -- Idle transition:
    -- Do NOT call EditModeOn here. MACH_STATE still contains the
    -- previous state at this point.
    if state == mc.MC_STATE_IDLE then
        return true, true,
                "Edit Offsets enable scheduled after state update"
    end
    -- Leaving Idle:
    -- Turn Edit Mode off immediately.
    local pa, pb, pc =
    if pb ~= true then
    end
end
-- PostScreenTabEnter Hook
-- CommonScreenV02 can automatically turn Edit Mode off when entering
-- tabs other than Tools / Fixtures.
-- This hook executes after normal tab processing, so restore the
-- Always-On policy here.
function UserGUIModule.PostScreenTabEnter(tab)
    local a, b, c =
            PreviousPostScreenTabEnter,
            tab
    if b ~= true then
    end
    if a == false then
        return false, b, c
    end
    end
    -- MACH_STATE is already current here, so an immediate restore
    -- is appropriate.
    local pa, pb, pc =
    if pb ~= true then
    end
end
-- UserPLCScript
-- Performs two jobs:
--   1. Services an Idle transition after CommonGUIModule has updated
--      MACH_STATE.
--   2. Acts as a throttled watchdog so Edit Offsets cannot remain
--      manually turned off while Mach is Idle.
function UserGUIModule.UserPLCScript()
    -- Preserve inherited / OEM PLC behavior first.
    local a, b, c =
    if b ~= true then
    end
    -- Do nothing in unsupported multi-instance configurations.
        return true, true,
            "Always-On Edit Offsets disabled"
    end
    -- HIGH PRIORITY:
    -- Service a pending Idle transition immediately.
    -- UserPLCScript executes after the Common PLC has refreshed
    -- MACH_STATE, so EditModeOn can now pass its normal state check.
    if PendingEditModeEnable then
        local pa, pb, pc =
        if pb ~= true then
        end
        -- ApplyAlwaysOnEditMode deliberately leaves the pending
        -- flag high if Cycle Start or state timing still requires
        -- another attempt.
        return true, true,
            "Pending Edit Offsets enable processed"
    end
    -- Normal watchdog.
    if EditModeWatchdogTimer:Time()
        < EDIT_MODE_WATCHDOG_MS then
        return true, true,
            "Edit Offsets watchdog waiting"
    end
    -- Apply normal Always-On policy.
    local pa, pb, pc =
    if pb ~= true then
    end
    return true, true,
        "Edit Offsets watchdog complete"
end
Make sure that this code exsists below "local UserGUIModule = ModuleLoader.RequireOEMUserGUIModule(UserGUIModule)" but above "return UserGUIModule.
Paul
« Reply #4 on: September 29, 2026, 05:56:19 PM »
Hi Paul,
thanks for that reply.
I'm still reading and trying to digest it all.
Seems like it might take a day or two before I can configure this.....I'll let you know how I get on.
I've been using Mach4 for twelve years and it has ALWAYS had a <ZeroAxis> button alongside the DRO. Yes, if you hit it inadvertently it causes trouble, but thats
not a reason to remove the functionality that I, and no doubt many others, have become accustomed to. It is our machines we are operating after all. If we wanted that functionality gone
we could have modified Mach4 to exclude the button in a few ketstrokes.
« Last Edit: September 29, 2026, 06:01:24 PM by joeaverage »
« Reply #5 on: September 30, 2026, 09:29:37 AM »
You may also be able to accomplish this through a GMS process, but that would still require some Lua programming and the creation of custom files to load.
The edit-offset controls were placed behind a tab and button to reduce the risk of accidental changes during normal operation. This decision was based on practical experience, not an attempt to remove functionality or limit customization.
Most of our design and workflow decisions have evolved through real-world experience. MachMotion, our sister company and the source of many of these changes, has retrofitted, built, or upgraded approximately 80 custom machines per year for the past 20 years. When a change becomes part of our standard process, it is generally because the same issue has occurred often enough to justify addressing it for all users.
The functionality remains available; the additional step is intended to help prevent an unintended offset change that could result in machine damage, a scrapped part, or a safety concern.
Paul
« Reply #6 on: September 30, 2026, 10:05:14 PM »
Could he create his own screen tab with the features he wants and have MachPro go to that page on startup?
Colten Edwards
www.lasernthings.ca
« Reply #7 on: October 05, 2026, 09:07:21 AM »
Craig,
I'm a bit of a dummy. There is a much easier way for you to handle your 'perfect DRO block' that I completely forgot about. There's already a setting for this.
Go to Service → Screen Config → Edit Offsets Auto Off, turn this to no. Once this is set, if you turn on your Edit Offsets, the offsets should stay on.
Ed,
Yes, a person can create their own screen tab that would be unaffected. If you want it to be the default tab that opens, go to the parent group elements properties and find "Default Tab", choose the tab number that you want on startup.
Paul
