Hello Guest it is November 11, 2026, 08:26:59 PM
Author Topic: connect 24VDC Quad (4 Channel) Relay Module to Pokeys57CNC  (Read 333502 times)
« on: September 17, 2026, 06:19:18 PM »
Hello,
Anyone connect 24VDC Quad (4 Channel) Relay Module to Pokeys57CNC?
Is this where I connect In1 In2 In3 In4 on Pokeys57CNC? Using OC1+,  OC2+, OC3+, OC4+?
Relatively new at this and Pokeys terminology not actually the same as other cheap controllers that I have used.
« Last Edit: September 17, 2026, 06:21:53 PM by Toner »
Re: connect 24VDC Quad (4 Channel) Relay Module to Pokeys57CNC
« Reply #1 on: September 22, 2026, 12:56:09 PM »
Update: Getting answers from PoLabs - Slovenia . "The OC outputs can be used to drive various external peripherals and such relay board is indeed one of them.
For a basic active high signal inputs, you can connect OC+ to the power supply for relay board logic, OC- to relay board input."
