Hello Guest it is November 15, 2026, 07:08:01 AM
Author Topic: Plate Alignment  (Read 61696 times)
Plate Alignment
« on: September 07, 2026, 04:07:54 PM »
Has anyone figured out how plate alignment is supposed to work? Two points and it will twist the gcode to match the alignment marks. My confusion is that I printed out a couple of pieces on my UV printer, added some alignment marks just like I would with Lightburn's Print and Cut. I can't wrap my head around what I need todo with MachPro's Plate Alignment in this case.
How do I tell MachPro which point in the gcode I'm using?
Colten Edwards
www.lasernthings.ca
Re: Plate Alignment
« Reply #1 on: September 14, 2026, 09:20:29 AM »
Here is our documentation we have on plate alignment:
If you're using the GUI funcitons
https://support.machmotion.com/books/cnc-software/page/machpro-plate-alignment-and-transform-functions
If you're using the Gcode:
https://support.machmotion.com/books/cnc-software/page/machpro-g-code-and-m-code-reference#bkmrk-g68-%E2%80%93-coordinate-s
Let me know if you have any questions or issues.
Paul
