Hello Guest it is October 21, 2026, 03:08:30 AM
Author Topic: WHB Pendant  (Read 51075 times)
WHB Pendant
« on: September 03, 2026, 12:34:56 PM »
COULD WE PLEASE GET THE DEFAULT STARTUP OF THE PENDANT TO BE CONTINOUS INSTEAD OF THE CURRENT STP MODE. I've asked this many times now. you do not want to know how many bit's I've broken because of this. So PLEASE change the default or at least have an option to save this setting so that it becomes the default.
Colten Edwards
www.lasernthings.ca
Re: WHB Pendant
« Reply #1 on: September 15, 2026, 12:53:41 PM »
I'll report this and push to get it changed. Just want to verify for clarities sake, it is the XHCmpg plugin you're using?
Paul
Re: WHB Pendant
« Reply #2 on: September 15, 2026, 01:36:08 PM »
yes. WHB06 pendant. I know it's not MachPro's, but they definitely look similar enough. Anyways, allowing a checkbox or radiobutton to toggle this as a default would be amazingly appreciated. I don't know how many bits I've driven down into my spoilboard or fixtures if I forget to toggle this from the controller. There must be a way todo this in software.
Colten Edwards
www.lasernthings.ca
Re: WHB Pendant
« Reply #3 on: September 16, 2026, 03:09:50 PM »
Yeah, the plugin was just ported over by popular request. I am having one of our developers dig in to a solution for this. I have prompted a couple of options we can do moving forward. I'll keep an eye on its stage and will let you know when a build is out for it.
Paul
Re: WHB Pendant
« Reply #4 on: September 16, 2026, 03:13:45 PM »
thank you. I am sure I'm not the only one who will appreciate this change.
Colten Edwards
www.lasernthings.ca
